Kingston 4GB DDR4 2666 MHz SODIMM Non-ECC CL19 Memory
Quicklinx: DL34WS00 Mfr#: KCP426SS6/4
Type: DDR4 SDRAM
Capacity: 4GB
Connection: SO-DIMM 260-pin
Speed: 1333MHz
Data Integrity: Non-ECC
£16.16 ex VAT
£19.39 inc VAT
Kingston DDR4 4 GB SO-DIMM 260-pin 2666 MHz / PC4-21300 CL17 1.2 V unbuffered non-ECC
Kingston - DDR4 - module - 4 GB - SO-DIMM 260-pin - 1333 MHz / PC4-21300 - unbuffered
Memory module
4 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC4-21300)
Latency Timings
CL17
Single rank, unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL17
Non-ECC
Module Configuration
512 x 64
Chips Organization
X8
Voltage
1.2 V
Lead Plating
Gold
Type: DDR4 SDRAM
Capacity: 4GB
Speed: 1333MHz
Registered/Buffered: Unbuffered
CAS Latency: CL17
Standard: PC4-21300
Brand: Kingston
