Kingston 4GB DDR4-2133MHz ECC Module
Quicklinx: C112WS00 Mfr#: KTL-TS421E/4G
Kingston memory is designed, manufactured and rigorously tested to meet the exact specifications of each brand name system. It’s guaranteed to be compatible and backed by a lifetime warranty and legendary Kingston reliability.
Kingston - DDR4 - module - 4 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
Memory module
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
Lenovo 4X70K14183
Limited lifetime warranty (Russia - 10 years)
Lenovo ThinkStation P310 30AS, 30AT, 30AU, 30AV
4 GB
Upgrade Type
System specific
Lenovo 4X70K14183
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Unbuffered
Module Configuration
512 x 72
Voltage
1.2 V
Lead Plating
Gold
