Kingston 4GB DDR3L DIMM 240-pin 1600 MHz/PC3L-12800 CL11 1.35V unbuffered non-ECC
Quicklinx: BYJMWS00 Mfr#: KCP3L16NS8/4
Type: DDR3L SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: Non-ECC
£16.16 ex VAT
£19.39 inc VAT
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - module - 4 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Single rank, Low Voltage, unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
Non-ECC
Module Configuration
512 x 64
Voltage
1.35 V
Lead Plating
Gold
Colour Category
Green
Type: DDR3L SDRAM
Capacity: 4GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3L-12800
Brand: Kingston
