- Kingston - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- HP AT913AA, HP 575480-001, HP 577606-001, HP AT913UT, HP VH641AA, HP AT913ET, HP 599092-002, HP 599092-001
- Limited lifetime warranty
- Designed For
- HP 100, 200, 3115, 42X, 45X, 60XX, 63X, 8200, Elite 8000; EliteBook 2170, 25XX, 27XX, 84XX, 85XX, 87XX; ENVY Laptop 13, 14, 15, 17, dv6, dv7; Mobile Thin Client 4320; Pavilion Laptop dv6, dv7; Pro All-in-One 3420; ProBook 43XX, 44XX, 45XX, 47XX, 53XX, 6360, 64XX, 65XX; TouchSmart 9300, Elite 7320
- Capacity
- 4 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Latency Timings
- CL9
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 204-pin
- Designed For
- HP EliteBook 2570p, 2760p, 8440p Notebook, 8440w Mobile Workstation, 8460p Notebook, 8460w Mobile Workstation, 8470p Notebook, 8470w Mobile Workstation, 8540p Notebook, 8540w Mobile Workstation, 8560p Notebook, 8560w Mobile Workstation, 8570w Mobile Workstation, 8740w Mobile Workstation, 8760w Mobile Workstation, 8770w Mobile Workstation , HP ENVY Laptop 13-1150ef, 14-1100el, 14-1114ef, 14-1154ca, 14-1155ca, 14-1180es, 14-1190eg, 14-1195ea, 14-1195eo, 14-1199ez, dv6-7200ea, dv6-7200sa, dv6-7201eg, dv6-7202eg, dv6-7202ss, dv6-7203es, dv6-7210us, dv6-7214nr, dv6-7214tx, dv6-7215nr, dv6-7220us, dv6-7222nr, dv6-7223nr, dv6-7227nr, dv6-7227sa, dv6-7228nr, dv6-7229nr, dv6-7240sg, dv6-7250ca, dv6-7251eo, dv6-7252eo, dv6-7254eo, dv6-7267cl, dv6-7276ez, dv6-7280la, dv6-7280sf, dv6-7290sf, dv6-7300ea, dv6-7300sa, dv6-7302eo, dv6-7370sf, dv7-7201eg, dv7-7202eg, dv7-7202ss, dv7-7203ea, dv7-7205tx, dv7-7212nr, dv7-7215sg, dv7-7230us, dv7-7240us, dv7-7243nr, dv7-7250us, dv7-7252eo, dv7-7259nr, dv7-7270ca, dv7-7290eb, dv7-7292eo, dv7-7299ef, dv7-7299sf , HP Pavilion Laptop dv6-2137el, dv6-3008et, dv6-3019wm, dv6-3025et, dv6-3035et, dv6-3101et, dv6-3102et, dv6-3104et, dv6-3105et, dv6-3107et, dv6-3112st, dv6-3113et, dv6-3120et, dv6-3320et, dv6-3340et, dv6-6186nr, dv6-6b31eo, dv6-6b48nr, dv6-6c11sz, dv6-6c82sl, dv6-7000sy, dv6-7001em, dv6-7002ed, dv6-7003ax, dv6-7003sm, dv6-7003sp, dv6-7004ss, dv6-7006ed, dv6-7009ss, dv6-7010eo, dv6-7010ss, dv6-7010us, dv6-7011eo, dv6-7013cl, dv6-7014nr, dv6-7020sg, dv6-7020us, dv6-7028tx, dv6-7029tx, dv6-7029wm, dv6-7030sz, dv6-7030tx, dv6-7031tx, dv6-7040sb, dv6-7041tx, dv6-7050eb, dv6-7050ez, dv6-7050sb, dv6-7050sw, dv6-7051sa, dv6-7053ea, dv6-7054sa, dv6-7055sa, dv6-7060sf, dv6-7061sa, dv6-7062sf, dv6-7063sa, dv6-7070el, dv6-7070sf, dv6-7070sw, dv6-7080eb, dv6-7084la, dv6-7086la, dv6-7090ef, dv6-7090el, dv6-7090sf, dv6-7099eo, dv6-7115nr, dv7-3169wm, dv7-4069wm, dv7-4197cl , HP Compaq Elite 8000
