Kingston 4GB 204-Pin DDR3 SO-DIMM Unbuffered DDR3 1333 (PC3 10600) System Specific Memory for Lenovo Model KTL-TP3B/4G
- Kingston - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- IBM 55Y3717
- Limited lifetime warranty
- Capacity
- 4 GB
- Upgrade Type
- System specific
- IBM 55Y3717
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 204-pin
