All KingstonĀ® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
- Kingston - DDR2 - kit - 4 GB: 2 x 2 GB - SO-DIMM 200-pin - 800 MHz / PC2-6400 - unbuffered
- Product Type
- Memory kit
- Capacity
- 4 GB: 2 x 2 GB
- Memory Type
- DDR2 SDRAM - SO-DIMM 200-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 800 MHz (PC2-6400)
- Unbuffered
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Capacity
- 4 GB: 2 x 2 GB
- Upgrade Type
- System specific
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- SO-DIMM 200-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 2 x memory - SO-DIMM 200-pin
