Kingston 4GB (1 x 4GB) HyperX Black 1600MHz DDR3 DIMM CL9
Quicklinx: 8GJJWS00 Mfr#: KHX16C9B1B/4
Be bold and aggressive with HyperX black. It features a sleek black heat-spreader for greater heat dissipation to optimize reliability. It adds some edge to your rig - and your game, with faster speeds and higher capacities - without a hit to your wallet. It's Intel XMP ready, with XMP profiles built into the modules, so higher performing frequencies, timings and voltage are just a click away.
HyperX blu Black Series - DDR3 - module - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL9
Black heatsink, unbuffered
Voltage
1.65 V
Lead Plating
Gold
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
Non-ECC
Module Configuration
512 x 64
Voltage
1.65 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
