Kingston 4GB (1 x 4GB) DDR3 1333MHz Laptop SODIMM CL9
Quicklinx: 7FRZWS00 Mfr#: KVR1333D3S9/4G
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Unbuffered
Voltage
1.5 V
Lead Plating
Gold
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL9
Non-ECC
Unbuffered
Module Configuration
512 x 64
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - SO-DIMM 204-pin
