ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
- Kingston ValueRAM - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9
- Unbuffered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Limited lifetime warranty
- Capacity
- 4 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Latency Timings
- CL9
- Non-ECC
- Unbuffered
- Module Configuration
- 512 x 64
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - SO-DIMM 204-pin
