Kingston 480GB SSDNow V300 SATA 6Gb/s 7mm 2.5" Solid State Drive Kit
Quicklinx: 93YKWS00 Mfr#: SV300S3B7A/480G
Get more life out of your computer and maximize your existing investment by replacing your old hard drive with a Kingston SSDNow V300 solid-state drive. It's the most cost-efficient way to dramatically improve the responsiveness of your system - and it's less disruptive than migrating your data to a new system.
SSDNow V300 features an LSI SandForce controller customized for Kingston and optimized for flash memory to deliver the utmost in quality and reliability from two leading SSD brands. Because it's made with solid-state components and has no moving parts, it's shock-proof and withstands drops and bumps.
Compressible Data Transfer (ATTO)
  • All capacities: 450MB/s Read and 450MB/s Write
Incompressible Data Transfer (AS-SSD and CrystalDiskMark)
  • 60GB -- 150MB/s Read and 50MB/s Write
  • 120GB -- 180MB/s Read and 133MB/s Write
  • 240GB -- 191MB/s Read and 142MB/s Write
  • 480GB -- 450MB/s Read and 208MB/s Write
IOMETER Maximum Random 4k Read/Write
  • 60GB -- up to 85,000/ up to 60,000 IOPS
  • 120GB -- up to 85,000/ up to 55,000 IOPS
  • 240GB -- up to 85,000/ up to 43,000 IOPS
  • 480GB -- up to 73,000/ up to 28,000 IOPS
PCMARK® Vantage HDD Suite Score
  • 60GB: 39,000
  • 120GB: 49,000
  • 240GB: 57,000
  • 480GB: 57,000
  • Enhanced durability
    Equipped with shock-resistant technology and a robust SandForce controller, the Kingston SSDNow V300 Desktop/Notebook Upgrade Kit ensures your data is safe even in the event of bumps or drops, making it a reliable choice for both desktops and notebooks.
  • Efficient performance
    Featuring a high internal data rate of 450 MBps for both read and write operations, and a maximum 4KB random write of 28,000 IOPS, this solid state drive delivers efficient performance for everyday computing tasks.
  • Energy-saving design
    With an active power consumption of just 2.052 W and an idle mode requiring only 0.64 W, the Kingston SSDNow V300 is designed to be energy efficient, reducing power costs and extending battery life in notebooks.
Kingston SSDNow V300 Desktop/Notebook Upgrade Kit - SSD - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
2.5" (in 3.5" carrier)
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, TRIM support, SandForce Driven, S.M.A.R.T.
69.8 mm x 100.1 mm x 7 mm
86 g
3-year warranty
480 GB
2.5"
SATA 6Gb/s
69.8 mm
100.1 mm
7 mm
86 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
450 MBps (read) / 450 MBps (write)
Maximum 4KB Random Write
28000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" or 3.5" (with included bay adapter)
Power Consumption
2.052 Watt (active) , 0.64 Watt (idle)
Software Included
Drivers & Utilities
3.5-inch bay adapter, 2.5" USB enclosure, 2.5mm mounting spacer
1 x Serial ATA cable - internal , 1 x Serial ATA power adapter - internal
Mounting Kit
Included
ISO 9001:2008
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
