Kingston's SSDNow mS200 mSATA solid-state drive oers a cost effective performance boost with a dual-drive option that allows room for adding high-capacity storage. Ideal for system builders, OEMs and enthusiasts, the mS200s ruggedly-cool, miniscule form factor is eight times smaller than a traditional 2.5-inch hard drive, making it perfect for notebooks, tablets and Ultrabooks. Available in capacities of up to 480GB, ms200 has a caseless, PCB-only design with no moving parts and is backed by a three-year warranty (30GB model has a two-year warranty), free technical support and legendary Kingston reliability.
- mSATA interface - fully compliant with industry standard, easy to fit, guaranteed to work
- NAND Flash memory based - shock-resistant with low power consumption
- Supports Intel's SRT - combines capacity advantage of HDD with performance improvements of SSD in dual-storage configuration
- Supports SMART - monitors the status of your drive
- Supports TRIM - maintains maximum performance on compatible operating systems
- Guaranteed - three-year warranty (two-year warranty on 30GB), free technical support
- Kingston SSDNow mS200 - SSD - 480 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 480 GB
- Form Factor
- mSATA
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, TRIM support, Smart Response Technology, SandForce SF-2241 controller, S.M.A.R.T.
- 30 mm x 50.88 mm
- 6.86 g
- 3-year warranty
- Capacity
- 480 GB
- Form Factor
- mSATA
- Interface
- SATA 6Gb/s
- 30 mm
- 50.88 mm
- 6.86 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 530 MBps (read) / 340 MBps (write)
- 4KB Random Read
- 21000 IOPS
- 4KB Random Write
- 13000 IOPS
- Maximum 4KB Random Write
- 18000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 52 pin mini-SATA
- Compatible Bay
- mSATA
- Power Consumption
- 1.8 Watt (write) , 0.4 Watt (idle) , 1.2 Watt (read)
- ISO 9001:2008
- Limited warranty - 3 years
- 0 °C
- 70 °C
