Kingston 480GB SSDNow E50 SSD SATA 3 2.5
Quicklinx: 9BRNWS00 Mfr#: SE50S37/480G
Kingston's SSDNow E50 features high IOPs and bandwidth performance to solve I/O latencies and bottlenecks and increase your server's performance. E50's 6 Gbps SATA interface provides max bandwidth over 500 MB/s read/write. This drive is built with MLC Sync NAND and is rated at 60,000 read/write IOPS versus an average IOPS rating of 300 for a 15K SAS HDD.
E50's advanced data integrity protection gives you peace of mind by ensuring a longer life for your data and your drive. DuraWrite extends the life of the SSD by efficiently reducing the Flash writes without sacrificing data integrity. RAISE technology provides superior protection against uncorrectable errors, while overprovisioning and advanced wear-leveling ensure consistent performance and wear over the life of the drive.
SSDNow E50 also features intelligent power failure protection to prevent data loss in case of a power failure.
  • Enhanced durability
    Equipped with DuraClass, DuraWrite, and RAISE technologies, this solid state drive offers enhanced durability and reliability, ensuring your data is safe even under the most demanding conditions.
  • High-speed performance
    With an internal data rate of up to 530 MB/s for reading and 500 MB/s for writing, coupled with 4KB random read IOPS of 53,000 and write IOPS of 32,000, this SSD delivers high-speed performance for all your storage needs.
  • Efficient power consumption
    Designed for efficiency, this SSD features an active power consumption of just 2.74 watts and drops to 1.25 watts when idle, making it an energy-efficient choice for your PC.
  • Advanced security
    The Kingston SSDNow E50 incorporates 128-bit AES encryption, providing advanced security for your data and ensuring it is protected against unauthorized access.
Kingston SSDNow E50 - SSD - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
Encryption Algorithm
128-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
DuraClass technology, SandForce Driven, DuraWrite technology, RAISE technology, Wear Leveling Support, SandForce SF-2581 controller, S.M.A.R.T., 128-bit AES
69.9 mm x 100 mm x 7 mm
92.34 g
3-year warranty
480 GB
128-bit AES
2.5"
SATA 6Gb/s
69.9 mm
100 mm
7 mm
92.34 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
530 MBps (read) / 500 MBps (write)
4KB Random Read
53000 IOPS
4KB Random Write
32000 IOPS
Maximum 4KB Random Write
36000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
2.74 Watt (active) , 1.25 Watt (idle)
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
