Move to faster performance with Kingston's SDHC/SDXC UHS-I U3 Flash card. With speeds of 90MB/s read and 80MB/s write, it reads up to 9x faster and writes up to 8x faster than standard Class 10 SD cards. It meets the SD Association's latest specification release, UHS-I U3 (Ultra High-Speed Bus, Speed Class 3), which guarantees performance of at least 30MB/s and enough bandwidth to record and playback 4K2K video without interruption.
Users can capture cinema-quality Full HD (1080p), Ultra HD (2160p), 3D and 4K2K videos on high-performance cameras such as Digital Single Lens Reflex (D-SLR), Digital Single Lens Mirrorless (D-SLM), camcorders and video cameras. It's ideal for television recordings as well as live broadcasts, plus it lets you edit files faster and provides faster upload times, especially when using USB 3.0 card readers. Its higher sustained write speeds ensure video integrity by reducing stutter and allow photographers to shoot in continuous burst mode.
Enhanced durability
Designed to withstand extreme conditions, this flash memory card operates flawlessly between -25°C and 85°C, ensuring your data is safe in any environment. -
High-speed performance
With read rates up to 90 MB/s and write rates up to 80 MB/s, this SDHC UHS-I memory card offers swift data transfer, making it ideal for high-resolution photography and 4K video recording. -
Secure data management
The inclusion of a write protection switch on this flash memory card prevents accidental data loss, providing an extra layer of security for your important files.
- Kingston - flash memory card - 32 GB - SDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- SDHC UHS-I Memory Card
- Storage Capacity
- 32 GB
- Speed Rating
- UHS Class 3
- Supply Voltage
- 3.3 V
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 32 GB
- Speed Class
- UHS Class 3
- Read Rate
- Up to 90 MB/s
- Write Rate
- Up to 80 MB/s
- Form Factor
- Supply Voltage
- 3.3 V
- Write protection switch
- ISO 9001:2008
- Limited warranty - lifetime
- 24 mm
- 32 mm
- 2.1 mm
- -25 °C
- 85 °C
