Kingston 32GB microSD UHS-I Industrial Temperature with SD Adaptor
Quicklinx: C9KJWS00 Mfr#: SDCIT/32GB
Type: microSDHC UHS-I Memory Card
Capacity: 32GB
SD Speed Class: UHS Class 1 / Class10
More than 50 In Stock
£25.52 ex VAT
£30.62 inc VAT
Kingston's industrial temperature microSD UHS-I has a wide operating temperature rating, making it suitable for harsh environments. It high operating temperature rating means it stands up to extreme heat in the desert and in test and measurement situations where standard microSD cards may fail, while its low operating temperature rating allows for use in below freezing weather, where equipment may be left outside for extended periods of time. Its high insertion rating is ideal for applications in which the card will be frequently accessed and removed from host devices, and its MLC NAND allows for large amounts of data to be written to the card.
With UHS-I speeds, the card is ideal for applications requiring greater bandwidth when recording large datasets. Higher sustained write speeds ensure data integrity by reducing transmission stutter, and the card also offers faster upload times when transferring files to a PC.
  • Industrial-grade features
    The card's wide operating temperature rating makes it perfect for harsh environments.
  • UHS-I interface
    Its UHS-I interface offers higher sustained write speeds to ensure data integrity by reducing transmission stutter.
  • MLC NAND
Kingston - flash memory card - 32 GB - microSDHC UHS-I
Flash memory card
Storage Capacity
32 GB
Speed Rating
MLC NAND Flash
Included Memory Adapter
microSDHC to SD adapter
5-year warranty
Flash memory card
Storage Capacity
32 GB
Speed Class
Read Rate
Up to 90 MB/s
Write Rate
Up to 45 MB/s
MLC NAND Flash
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - 5 years
11 mm
15 mm
Thickness
1 mm
-40 °C
85 °C
Capacity: 32GB
Brand: Kingston
