Your basket is empty
Kingston 32GB IronKey W700 WTG FIPS USB 3.0
Quicklinx: BZTBWS00 Mfr#: IKW700/32GB
Today’s organizations are employing more mobile workers than ever before. Field personnel, consultants and teleworkers all need a mobile computing environment that gives them access to corporate applications and data, without the burden or expense of lugging a laptop. For many enterprises, that environment is Microsoft Windows To Go, a complete Windows 8 Enterprise workspace that can be booted directly from a USB flash drive or other storage device to run on any PC1, regardless of operating system. With Windows To Go, you can: • Provide your users with an imaged and fully functional version of Windows 8 Enterprise. • Distribute mobile work environments that mirror your corporate desktop. • Ensure employees, partners and contractors are using mobile workspaces created and managed by IT. Not every mobile Windows solution is created equal. And when you’re working with corporate data and applications, you need a solution you can trust. Now there’s IronKey Workspace W700 — the drive certified by Microsoft for Windows To Go that delivers a true Windows 8 desktop embedded in a trusted IronKey USB flash drive.
IronKey Workspace W700 - USB flash drive - Windows To Go certified - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, 256-bit AES, 256-bit AES-XTS
Microsoft Windows 7 or later
Windows To Go Certification
5 years warranty
USB flash drive
Storage Capacity
32 GB
Hardware Encryption
Compatibility
Non-specific
Read Rate
Up to 400 MB/s
Write Rate
Up to 316 MB/s
Interface Type
USB 3.0
Encryption support, bootable, password protection, shockproof, waterproof, dustproof, ruggedized, metal body, Cryptochip, CAC/PIV login
Limited warranty - 5 years
82.3 mm
21.1 mm
9.1 mm
32 g
70 °C
