Kingston 32GB IronKey S250 Basic FIPS USB 2.0
Quicklinx: BZSTWS00 Mfr#: IKS250B/32GB
Capacity: 32GB
Interface: USB 2.0
£584.68 ex VAT
£701.61 inc VAT
Designed specifically for enterprise, government and military customers that need high performance and reliability in their USB flash storage devices, IronKey Basic S250 flash drive meets the extreme performance and security requirements of some even very demanding organizations. It is equipped with strong hardware encryption. A ruggedized, waterproof metal chassis helps protect S250 drive from the elements, and active anti-malware prevents USB threats from spreading.
  • Built to be a secure flash drive
    Designed specifically for enterprise, government and military customers that need high performance and reliability in their USB flash storage devices, IronKey Basic S250 flash drive meets the extreme performance and security requirements of some very demanding organizations. It is equipped with strong hardware encryption. A ruggedized, waterproof metal chassis helps protect S250 drive from the elements, and active anti-malware prevents USB threats from spreading.
  • Faster performance, longer life
    The IronKey Basic S250 features dual-channel memory and reads files at up to 29 mg/sec.
  • Safer, hardware-based encryption
    Flash storage drives that rely on software to enable encryption keys are vulnerable to cold-boot and malware attacks because they export AES encryption keys to the host PC. IronKey drive instead uses the IronKey Cryptochip, a proven hardware-based solution that keeps key management on the IronKey drive and off the host PC. After users plug in an IronKey Basic S250 drive, they must first authenticate with a password. Only then does IronKey's Cryptochip enable the encryption keys that unlock data and applications.
  • Designed to foil malware and thieves
    IronKey's hardware-based encryption and password verification can't be disabled by malware or a careless user. Self-defending IronKey drive also provides active protections against the spread of worms, crimeware and other malicious code. And if a thief enters 10 incorrect passwords in an attempt to break into the drive, the Cryptochip will securely erase all encrypted data.
  • Protection that never sleeps
    Unlike software-based encryption, IronKey's AES 256- bit hardware encryption is always on and can't be disabled. And with the IronKey Cryptochip handling encryption, PC performance doesn't suffer.
  • Built to last
    Shielded in a solid, tamper-resistant and waterproof metal casing, IronKey drive is built to survive long time of wear and tear.
IronKey Basic S250 - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
32 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, 256-bit AES, 2048-bit RSA, 256-bit SHA
SLC NAND Flash
Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Apple MacOS X 10.9 - 10.11, Windows 8.1 / 10
5-year warranty
USB flash drive
Storage Capacity
32 GB
Hardware Encryption
Read Rate
Up to 31 MB/s
Write Rate
Up to 24 MB/s
Interface Type
USB 2.0
SLC NAND Flash
Password protection, waterproof, tamper-proof, ruggedized, metal body, Cryptochip
Limited warranty - 5 years
75 mm
19 mm
9 mm
25 g
70 °C
Capacity: 32GB
Interface: USB 2.0
Brand: Kingston
Price Range Ex VAT: £500 - £750
