Kingston 32GB DDR4-2666MHz Reg ECC Memory
Quicklinx: DQPZWS00 Mfr#: KCS-UC426/32G
Type: DDR4 SDRAM
Capacity: 32GB
Connection: DIMM 288-pin
Speed: 1333MHz
Data Integrity: ECC
£367.99 ex VAT
£441.58 inc VAT
Kingston DDR4 32 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 - 1.2 V registered ECC for Cisco UCS SmartPlay Select C220 M5SX, SmartPlay Select C240 M5L
Kingston - DDR4 - module - 32 GB - DIMM 288-pin / PC4-21300 - registered
Memory module
32 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2666 MT/s (PC4-21300)
Latency Timings
CL19
Registered
Voltage
1.2 V
Lead Plating
Gold
Cisco UCS-MR-X32G2RS-H
Limited lifetime warranty (Russia - 10 years)
Cisco UCS B200 M5, C125 M5, C220 M5, C220 M5SN, C220 M5SX, C240 M5, C480, S3260, S3260 M5, SmartPlay Select B200 M5, SmartPlay Select C220 M5, SmartPlay Select C220 M5S, SmartPlay Select C220 M5SX, SmartPlay Select C240 M5, SmartPlay Select C240 M5L, SmartPlay Select C240 M5SX
32 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL19
ECC
Registered
Module Configuration
4096 x 72
Voltage
1.2 V
Lead Plating
Gold
Cisco UCS B200 M5 Blade Server (Tracer), C125 M5, C220 M5 Server (Large Form Factor Disk Drive Model), C220 M5SN SFF, C240 M5 LFF Rack Server, C240 M5 LFF Rack Server (Tracer), C240 M5 SFF Rack Server, C480 ML M5, S3260 M5 Server Node with I/O Expander configurable, S3260 Storage Server, SmartPlay Select B200 M5, SmartPlay Select B200 M5 (Not sold standalone), SmartPlay Select B200 M5 (Tracer), SmartPlay Select B200 M5 Advanced 1 (Tracer), SmartPlay Select B200 M5 Advanced 2 (Tracer), SmartPlay Select B200 M5 Advanced 3, SmartPlay Select B200 M5 Advanced 4 (Tracer), SmartPlay Select B200 M5 Basic 1, SmartPlay Select B200 M5 Basic 1 (Tracer), SmartPlay Select B200 M5 High Core 1 (Tracer), SmartPlay Select B200 M5 High Core 2 (Tracer), SmartPlay Select B200 M5 High Frequency 1 (Tracer), SmartPlay Select B200 M5 High Frequency 2, SmartPlay Select B200 M5 High Frequency 3, SmartPlay Select B200 M5 High Frequency 3 (Tracer), SmartPlay Select B200 M5 Standard 1 (Tracer), SmartPlay Select B200 M5 Standard 2 (Tracer), SmartPlay Select C220 M5 High Core 1, SmartPlay Select C220 M5 Standard 1, SmartPlay Select C220 M5 Standard 2, SmartPlay Select C220 M5S Basic 1 (Tracer), SmartPlay Select C220 M5S Standard 1 (Tracer), SmartPlay Select C220 M5SX, SmartPlay Select C220 M5SX (Tracer), SmartPlay Select C220 M5SX Advanced 1 (Tracer), SmartPlay Select C220 M5SX Advanced 2, SmartPlay Select C220 M5SX Advanced 2 (Tracer), SmartPlay Select C220 M5SX Basic 1, SmartPlay Select C220 M5SX High Core 2, SmartPlay Select C220 M5SX Standard 2 (Tracer), SmartPlay Select C240 M5 Standard 1, SmartPlay Select C240 M5L High Frequency 1, SmartPlay Select C240 M5L High Frequency 2, SmartPlay Select C240 M5L Standard 1, SmartPlay Select C240 M5L Standard 2, SmartPlay Select C240 M5SX (Tracer), SmartPlay Select C240 M5SX Advanced 1, SmartPlay Select C240 M5SX High Frequency 2, SmartPlay Select C240 M5SX Standard 2
Type: DDR4 SDRAM
Capacity: 32GB
Speed: 1333MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL19
Standard: PC4-21300
Brand: Kingston
