Kingston 32GB DDR4 2666MHz ECC Memory
Quicklinx: DQQFWS00 Mfr#: KTL-TS426/32G
Kingston DDR4 32 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V registered ECC for Lenovo ThinkSystem SD530; SN850; SR550; SR570; SR590; SR650; SR850; SR860; SR950; ST550
Kingston - DDR4 - module - 32 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
Memory module
32 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19
Registered
Voltage
1.2 V
Lead Plating
Gold
Lenovo 7X77A01304
Limited lifetime warranty (Russia - 10 years)
Lenovo ThinkAgile HX1321 Certified Node; HX2320 Appliance; HX3321 Certified Node; HX7820 Appliance; HX7821 Certified Node; MX1020 Appliance; MX1021 Certified Node; ThinkAgile VX Certified Node 7Y94; ThinkAgile VX3320 Appliance; VX3720 Appliance; VX5520 Appliance; VX7520 Appliance; ThinkSystem SE350
32 GB
Upgrade Type
System specific
Lenovo 7X77A01304
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL19
ECC
Registered
Module Configuration
4096 x 72
Voltage
1.2 V
Lead Plating
Gold
Lenovo ThinkAgile HX1321 Certified Node 7Y89 , Lenovo ThinkAgile HX2320 Appliance 7X83 , Lenovo ThinkAgile HX2321 Certified Node 7Y89 , Lenovo ThinkAgile HX3321 Certified Node 7Y89 , Lenovo ThinkAgile HX3520-G Appliance 7X84 , Lenovo ThinkAgile HX3721 Certified Node 7Y88 , Lenovo ThinkAgile HX7520 Appliance 7X84 , Lenovo ThinkAgile HX7820 Appliance 7Y95 , Lenovo ThinkAgile HX7821 Certified Node 7Y96, 7Z09 , Lenovo ThinkAgile MX1020 Appliance 7D5S , Lenovo ThinkAgile MX1021 Certified Node 7D1B , Lenovo ThinkAgile VX 1U Certified Node 7Y93 , Lenovo ThinkAgile VX 2U Certified Node 7Y94 , Lenovo ThinkAgile VX 2U4N Certified Node 7Y92 , Lenovo ThinkAgile VX Certified Node 7Y94 , Lenovo ThinkAgile VX2320 Appliance 7Y93 , Lenovo ThinkAgile VX3320 Appliance 7Y93 , Lenovo ThinkAgile VX3520-G Appliance 7Y94 , Lenovo ThinkAgile VX3720 Appliance 7Y92 , Lenovo ThinkAgile VX5520 Appliance 7Y94 , Lenovo ThinkAgile VX7520 Appliance 7Y94 , Lenovo ThinkSystem SD530 7X21 , Lenovo ThinkSystem SE350 7D1X, 7Z46 , Lenovo ThinkSystem SN550 , Lenovo ThinkSystem SN850 , Lenovo ThinkSystem SR530 7X07, 7X08 , Lenovo ThinkSystem SR550 7X03, 7X04 , Lenovo ThinkSystem SR570 7Y02, 7Y03 , Lenovo ThinkSystem SR590 7X98, 7X99 , Lenovo ThinkSystem SR630 7X02 , Lenovo ThinkSystem SR650 , Lenovo ThinkSystem SR670 7Y37 , Lenovo ThinkSystem SR850 7X19 , Lenovo ThinkSystem SR860 7X69 , Lenovo ThinkSystem SR950 , Lenovo ThinkSystem ST550 7X09, 7X10
