Kingston 32GB DDR4 2666MHz ECC Memory
Quicklinx: DQQ2WS00 Mfr#: KTD-PE426/32G
Type: DDR4 SDRAM
Capacity: 32GB
Connection: DIMM 288-pin
Speed: 2666MHz
Data Integrity: ECC
£378.97 ex VAT
£454.76 inc VAT
Kingston memory is designed, manufactured and rigorously tested to meet the exact specifications of each system. It's guaranteed to be compatible and backed by legendary Kingston reliability.
Kingston - DDR4 - module - 32 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
Memory module
32 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19
Registered
Voltage
1.2 V
Lead Plating
Gold
DELL A9781929
Limited lifetime warranty (Russia - 10 years)
Dell PowerEdge C4130, C4140, C6420, FC430, FC630, FC830, M630, M830, MX740c, MX840c, T430, T630; Precision 5820 Tower, 7820 Tower, 7920 Rack, 7920 Tower; Precision Tower 5810
32 GB
Upgrade Type
System specific
DELL A9781929
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL19
ECC
Registered
Module Configuration
4096 x 72
Voltage
1.2 V
Lead Plating
Gold
Dell PowerEdge C4130, C4140, C6420, FC430, FC630, FC830, M630, M830, MX740c, MX840c, T430, T630 , Dell Precision 5820 Tower, 7820 Tower, 7920 Rack, 7920 Tower , Dell Precision Tower 5810
Type: DDR4 SDRAM
Capacity: 32GB
Speed: 2666MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL19
Standard: PC4-21300
Brand: Kingston
