Kingston manufacture the most reliable memory you can buy for a Lenovo Server. Kingstons legendary reputation is built around reliable memory, that will power your Lenovo server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Lenovo compatible memory module.
Each chip that is built onto the Lenovo memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of Lenovo server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all Lenovo memory upgrades for Server environments.
- Kingston - DDR4 - module - 32 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - registered
- Product Type
- Memory module
- Capacity
- 32 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2400 MHz (PC4-19200)
- Latency Timings
- CL17
- Registered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Lenovo Flex System x240 M5 9532; Storage DX8200C 5120; System x3650 M5 8871
- Capacity
- 32 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL17
- ECC
- Registered
- Module Configuration
- 4096 x 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
- Lenovo Flex System x240 M5 9532 , Lenovo Storage DX8200C 5120 , Lenovo System x3650 M5 8871
