Kingston 32GB DDR4-2400MHz Reg ECC Module
Quicklinx: C53WWS00 Mfr#: KTD-PE424/32G
Kingston manufacture the most reliable memory you can buy for Servers from Dell. Kingstons legendary reputation is built around reliable memory, that will power your server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Dell compatible memory module.
Each chip that is built onto the Dell memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of server memory upgrades for Dell. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all Dell memory upgrades for Server environments.
Kingston - DDR4 - module - 32 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - registered
Memory module
32 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Registered
Voltage
1.2 V
Lead Plating
Gold
DELL A8711888
Limited lifetime warranty (Russia - 10 years)
Dell PowerEdge C4130, C6320, FC430, FC630, FC830, M630, M830, T430, T630; Precision Rack 7910; Precision Tower 5810, 7810, 7910
32 GB
Upgrade Type
System specific
DELL A8711888
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Registered
Module Configuration
4096 x 72
Voltage
1.2 V
Lead Plating
Gold
Dell PowerEdge C4130, C6320, FC430, FC630, FC830, M630, M830, T430, T630 , Dell Precision Rack 7910 , Dell Precision Tower 5810, 7810, 7910
