Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR4 - module - 32 GB - LRDIMM 288-pin - 2133 MHz / PC4-17000 - LRDIMM
- Product Type
- Memory module
- Capacity
- 32 GB
- Memory Type
- DDR4 SDRAM - LRDIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Quad rank, Load-Reduced
- Voltage
- 1.2 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- IBM 46W0800, IBM 46W0799
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Lenovo Flex System x240 M5 9532
- Capacity
- 32 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- LRDIMM 288-pin
- Speed
- Latency Timings
- CL15
- ECC
- Module Configuration
- 4096 x 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
