Kingston 2TB KC600 2.5" 7mm SATA 6Gb/s SSD
Quicklinx: FM76WS00 Mfr#: SKC600/2048G
Form Factor: 2.5
Capacity: 2TB, 2TB
Interface: Serial ATA-600
Type: Internal hard drive
Hurry, only 1 left in stock!
£358.89 ex VAT
£430.66 inc VAT
  • Enhanced security
    Equipped with 256-bit AES-XTS encryption, this solid state drive offers high-level security for your data, ensuring peace of mind with Self-Encrypting Drive (SED) and TCG Opal Encryption capabilities.
  • High capacity storage
    With a generous 2 TB capacity, this drive provides ample space for your extensive digital collections, from high-resolution photos to large video files, all housed in a convenient 2.5" form factor.
  • Efficient performance
    Leveraging the Silicon Motion SM2259 controller and 3D NAND technology, the KC600 delivers impressive data transfer rates up to 600 MB/s, with internal rates of 550 MB/s read and 520 MB/s write, optimizing your computing experience.
  • Durability and reliability
    Designed to withstand the rigors of daily use, this SSD boasts a shock and vibration tolerance that ensures your data remains safe and accessible, complemented by an MTBF of 1,000,000 hours for long-term reliability.
  • Energy efficient
    This drive's power consumption is meticulously optimized for efficiency, with an average operating power of 0.2 W, reducing your carbon footprint while maintaining peak performance during read and write operations.
Kingston KC600 - SSD - 2 TB - SATA 6Gb/s
Solid state drive - internal
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES-XTS
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
3D NAND Technology, Silicon Motion SM2259 controller, eDrive
69.85 mm x 100.1 mm x 7 mm
40 g
5-year warranty
2 TB
Hardware Encryption
256-bit AES-XTS
2.5"
SATA 6Gb/s
69.85 mm
100.1 mm
7 mm
40 g
Performance
SSD Endurance
1200 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
80000 IOPS
Maximum 4KB Random Read
90000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
0.2 watt (average) , 0.06 watt (idle) , 1.3 watt (read) , 3.2 watt (write)
Limited warranty - 5 years , Technical support
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Form Factor: 2.5
Capacity: 2TB
Capacity: 2TB
Brand: Kingston
