Kingston 2GB DDR2 800MHz Module
Quicklinx: 56N4WS00 Mfr#: KTD-DM8400C6/2G
All KingstonĀ® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - module - 2 GB - DIMM 240-pin - 800 MHz / PC2-6400 - unbuffered
Memory module
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Unbuffered
DELL A2055829
Limited lifetime warranty (Germany, Austria and France - 10 years)
Dell Inspiron 535s, 537s; OptiPlex 330, 330n, 740, 740 MLK, 740n, 745, 745c, 755, 755n, GX620; Precision T3400; XPS 410, 410 N
2 GB
Upgrade Type
System specific
DELL A2055829
DRAM memory module
DDR2 SDRAM
DIMM 240-pin
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Dell Inspiron 535s, 537s , Dell OptiPlex 330, 330n, 740, 740 MLK, 740n, 745, 745c, 755, 755n, GX620 , Dell Precision T3400 , Dell XPS 410, 410 N
