Kingston 2GB DDR2-800 Module
Quicklinx: 6DF9WS00 Mfr#: KAC-MEMG/2G
All KingstonĀ® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - module - 2 GB - SO-DIMM 200-pin - 800 MHz / PC2-6400 - unbuffered
Memory module
2 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Unbuffered
Limited lifetime warranty (Germany, Austria and France - 10 years)
Acer Aspire 2930, 4930, 5930, 7730; TravelMate 4730, 5730
2 GB
Upgrade Type
System specific
DRAM memory module
DDR2 SDRAM
SO-DIMM 200-pin
Speed
800 MHz (PC2-6400)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 200-pin
Acer Aspire 2930, 2930-6850, 2930-844G32MN, 4930-6862, 5930-733G25Mi, 7730 , Acer TravelMate 4730-842G16Mn, 5730, 5730-5B2G16MN, 5730-5B2G32MN, 5730-6953, 5730-6B2G16Mn, 5730-6B2G16N, 5730-6B2G25Mn, 5730-6B2G25N, 5730-6B2G32N, 5730-6B3G16MN, 5730-6B3G25N, 5730-6B4G25Mn, 5730-6B4G25N, 5730-6B4G32Mn, 5730-842G16Mn, 5730-842G25MN, 5730-842G25N, 5730-844G25N, 5730-844G32Mn, 5730-862G25Mn, 5730-944G32Mn, 5730-944G32N
