All KingstonĀ® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
- Kingston - DDR2 - module - 2 GB - DIMM 240-pin - 800 MHz / PC2-6400 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 800 MHz (PC2-6400)
- Latency Timings
- CL6
- Unbuffered
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- Gateway FX540X, FX540XT, FX540XV; MAXDATA Favorit 4000 I, 4000 IS, 4000 IT BTX
- Capacity
- 2 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL6
- Non-ECC
- Unbuffered
- Module Configuration
- 256 x 64
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Gateway FX540X, FX540XT, FX540XV , MAXDATA Favorit 4000 I, 4000 IS, 4000 IT BTX
