Kingston 256GB KC600 2.5" 7mm SATA 6Gb/s SSD
Quicklinx: FHCDWS00 Mfr#: SKC600/256G
Form Factor: 2.5
Capacity: 256GB
Interface: Serial ATA-600
Type: Internal hard drive
16 In Stock
£37.67 ex VAT
£45.20 inc VAT
Kingston's KC600 is a full capacity SSD designed to provide remarkable performance and optimized to provide functional system responsiveness with incredible boot, loading, and transfer times. The KC600 utilizes 3D TLC NAND technology while supporting a full-security suite.
  • Easy installation/upgrade
    KC600 is available in an upgrade bundle kit that has everything you need to easily install your drive.
  • Full-security suite
    Protect and secure your data with Kingston's self-encrypting drive.
Kingston KC600 - SSD - 256 GB - SATA 6Gb/s
Solid state drive - internal
256 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
3D NAND Technology, Silicon Motion SM2259 controller, eDrive
69.85 mm x 100.1 mm x 7 mm
40 g
5-year warranty
256 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
69.85 mm
100.1 mm
7 mm
40 g
Performance
SSD Endurance
150 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 500 MBps (write)
Maximum 4KB Random Write
80000 IOPS
Maximum 4KB Random Read
90000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
0.2 watt (average) , 0.06 watt (idle) , 1.3 watt (read) , 3.2 watt (write)
Limited warranty - 5 years , Technical support
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Form Factor: 2.5
Capacity: 256GB
Brand: Kingston
