Kingston 256GB Canvas Select Plus SD Card
Quicklinx: FQ9ZWS00 Mfr#: SDS2/256GB
24 left in stock
£14.51 ex VAT
£17.41 inc VAT
Kingston's Canvas Select Plus SD card is designed with exceptional performance, speed, and durability for heavy workloads such as transferring and developing high-resolution photos or capturing and editing Full HD videos. It can reach Class 10 UHS-I speeds up to 100MB/s for easy storage and quick transfers along with an advanced UHS-I interface that can record cinematic Full HD and 4K Ultra HD videos. The Canvas Select Plus SD card is built to perform in the harshest environments and conditions so you can take it anywhere knowing your files, photos, and videos are protected.
  • Enhanced durability
    Designed to withstand challenging conditions, the Kingston Canvas Select Plus is X-ray proof, shockproof, temperature-proof, and waterproof. This resilience ensures your data remains safe, whether you're braving the great outdoors or navigating the urban jungle.
  • High-speed performance
    With a read rate of 100 MB/s and a write rate of 85 MB/s, this SDXC UHS-I memory card offers performance for both reading and writing data. Ideal for video recording and photography, it supports Video Class V30 / UHS-I U3 / Class10 speed classes, ensuring smooth video capture and quick file transfers.
Kingston Canvas Select Plus - flash memory card - 256 GB - SDXC UHS-I
Flash memory card
SDXC UHS-I Memory Card
Storage Capacity
256 GB
Speed Rating
Flash memory card
Storage Capacity
256 GB
Speed Class
Read Rate
Up to 100 MB/s
Write Rate
Up to 85 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
Type: SDXC UHS-I Memory Card
Capacity: 256GB
SD Speed Class: Video Class V30 / UHS-I U3 / Class10
Brand: Kingston
Stock Status: While stocks last
Stock Status: Clearance
