Kingston's Canvas Go! card is designed to be used on the go, making it ideal for filming life's adventures. You can be confident that your memories will be safe when documenting the next journey on your DSLR, drone or action camera.
Made for movement
Capture your latest hike, underwater adventure or that sweeping landscape using this card. -
Get your memories faster
Transfer and edit your memories quicker thanks to the incredible read speeds.
- Kingston Canvas Go! - flash memory card - 256 GB - SDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- SDXC UHS-I Memory Card
- Storage Capacity
- 256 GB
- Speed Rating
- Video Class V30 / UHS-I U3 / Class10
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 256 GB
- Compatibility
- Non-specific
- SD Speed Class
- Read Rate
- Up to 90 MB/s
- Write Rate
- Up to 45 MB/s
- Form Factor
- Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
- Limited warranty - lifetime
- 24 mm
- 32 mm
- 2.1 mm
- -25 °C
- 85 °C
