Kingston's UV500 family of solid-state drives dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a Marvell Dean controller combined with 3D NAND Flash for read and write speeds up to 520MB/s and 500MB/s, this SSD is 10X faster than a traditional hard drive for better performance, ultra-responsive multi-tasking and an overall faster system. UV500 provides end-to-end data protection, supports 256-bit AES hardware-based encryption and TCG Opal 2.0 security management solutions. More reliable and durable than a hard drive, UV500 is built with NAND Flash semiconductor memory. There are no moving parts, making it far less likely to fail than a mechanical hard drive. It is also cooler and quieter, and its shock and vibration resistance makes it ideal for notebooks and other mobile computing devices.
Encrypted protection
Protect sensitive data with support for 256-bit AES hardware-based encryption and TCG Opal 2.0. -
10X faster than a hard drive
With incredible read/write speeds, the UV500 will not only increase performance, but can also breathe a life into older systems.
- Kingston UV500 - SSD - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- 3D triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Marvell 88SS1074 controller, 3D NAND Technology, End-to-end data protection
- 69.85 mm x 100.1 mm x 7 mm
- 41 g
- 5-year warranty
- Capacity
- 240 GB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.1 mm
- 7 mm
- 41 g
Performance
- SSD Endurance
- 100 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 520 MBps (read) / 500 MBps (write)
- Maximum 4KB Random Write
- 25000 IOPS
- Maximum 4KB Random Read
- 79000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 0.5 watt (average) , 0.195 watt (idle) , 1.17 watt (read) , 2.32 watt (write)
- Limited warranty - 5 years , Technical support
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
