Kingston's KC380 SSDNow solid-state drive features a small case form factor that fits in notebooks, sub-notebooks, tablet PCs and netbooks with a smaller physical device storage footprint. Lighter than a traditional hard drive, it lets users take advantage of the durability, reliability and performance improvements of Flash memory in systems currently using 1.8" hard drives and is the ultimate hard drive replacement.
KC380 consumes less power and generates less heat than a traditional HDD - at a fraction of the cost of a new system. It offers advanced data integrity protection and a SandForce second-generation SSD processor with DuraClass technology. DuraClass features include DuraWrite and advanced wear-leveling to extend the life of the drive and garbage collection and over-provisioning for consistent performance and a longer life for your SSD and your data.
- Kingston SSDNow KC380 - solid state drive - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- Form Factor
- 1.8"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, DuraClass technology, SandForce Driven, DuraWrite technology, Garbage Collection technology, Wear Leveling Support, S.M.A.R.T.
- 54 mm x 78.5 mm x 5 mm
- 27.43 g
- 3-year warranty
- Capacity
- 240 GB
- Form Factor
- 1.8"
- Interface
- SATA 6Gb/s
- 54 mm
- 78.5 mm
- 5 mm
- 27.43 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 540 MBps (read) / 530 MBps (write)
- 4KB Random Read
- 21000 IOPS
- 4KB Random Write
- 41000 IOPS
- Maximum 4KB Random Write
- 40000 IOPS
- Maximum 4KB Random Read
- 72000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 16 pin Micro Serial ATA
- Compatible Bay
- 1.8"
- Power Consumption
- 1.8 Watt (write) , 0.4 Watt (idle) , 1.2 Watt (read)
- Limited warranty - 3 years , Technical support
- 0 °C
- 70 °C
- Vibration Tolerance
- 2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
