Kingston 240GB SSDNow E50 SSD SATA 3 2.5
Quicklinx: 9BRMWS00 Mfr#: SE50S37/240G
Kingston's SSDNow E50 features high IOPs and bandwidth performance to solve I/O latencies and bottlenecks and increase your server's performance. E50's 6 Gbps SATA interface provides max bandwidth over 500 MB/s read/write. This drive is built with MLC Sync NAND and is rated at 60,000 read/write IOPS versus an average IOPS rating of 300 for a 15K SAS HDD.
E50's advanced data integrity protection gives you peace of mind by ensuring a longer life for your data and your drive. DuraWrite extends the life of the SSD by efficiently reducing the Flash writes without sacrificing data integrity. RAISE technology provides superior protection against uncorrectable errors, while overprovisioning and advanced wear-leveling ensure consistent performance and wear over the life of the drive.
SSDNow E50 also features intelligent power failure protection to prevent data loss in case of a power failure.
  • Enhanced durability
    Equipped with DuraClass, DuraWrite, and RAISE technologies, the Kingston SSDNow E50 ensures durability and reliability, safeguarding your data against everyday wear and tear.
  • High-speed performance
    With an internal data rate of up to 550 MBps for reading and 530 MBps for writing, alongside maximum 4KB random reads of 85,000 IOPS and writes of 73,000 IOPS, this SSD delivers swift and efficient performance for all your computing needs.
  • Efficient power consumption
    The SSDNow E50 features an active power consumption of just 2.74 W and an idle power consumption of 1.25 W, making it an energy-efficient choice for your PC.
  • Advanced security
    This solid state drive comes with 128-bit AES encryption, providing a secure layer to protect your sensitive data from unauthorized access.
  • Extended reliability
    Boasting an MTBF of 1,000,000 hours, the Kingston SSDNow E50 is built to last, offering peace of mind with its reliable performance over time.
Kingston SSDNow E50 - SSD - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
Encryption Algorithm
128-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
DuraClass technology, SandForce Driven, DuraWrite technology, RAISE technology, Wear Leveling Support, SandForce SF-2581 controller, S.M.A.R.T., 128-bit AES
69.9 mm x 100 mm x 7 mm
92.34 g
3-year warranty
240 GB
128-bit AES
2.5"
SATA 6Gb/s
69.9 mm
100 mm
7 mm
92.34 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 530 MBps (write)
4KB Random Read
48000 IOPS
4KB Random Write
72000 IOPS
Maximum 4KB Random Write
73000 IOPS
Maximum 4KB Random Read
85000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
2.74 Watt (active) , 1.25 Watt (idle)
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
