Kingston’s KC1000 solid-state drive is a high-performance PCIe NVMe™ solution that is over 2x faster than SATA-based SSDs and 40x faster than a 7200RPM hard-disk drive. Using a PCIe Gen 3.0 x4 interface and an 8-channel Phison PS5007-E7 controller, this drive features 4 cores and 2x the DRAM to help power users blaze through even the toughest projects with high-speed data transfers of up to 2700MB/s.
KC1000 uses native OS drivers and is NVMe 1.2 compliant which allows users to take full advantage of the high throughput, IOPS and low latency that is available to systems that support NVMe. This protocol was designed specifically to support Flash-based storage versus SATA, which was developed for traditional spinning disks. It removes performance bottlenecks and provides the system with instant access to the device once the SSD is installed.
KC1000 is easily installed in either a standard M.2 or PCI Express socket using the M.2 2280 or the half-height, half-length add-in card for greater design-in flexibility when used by system builders. There is a range of capacities available from 240GB to 960GB, and the KC1000 is backed by a limited five-year warranty* and legendary Kingston support.
• High-performance, next-generation PCIe NVMe SSD • NVMe — Designed for SSDs, not legacy storage products • Form factor choices to fit a wide range of systems
- Based on "out-of-box performance" using a SATA Rev. 3.0/ PCIe 3.0 motherboard. Speed may vary due to host hardware, software and usage. IOMETER random 4K random read/write is based on an 8GB partition.
** Some of the listed capacity on a Flash storage device is used for formatting and other functions and is thus not available for data storage. As such, the actual available capacity for data storage is less than what is listed on the products. For more information, go to Kingston’s Flash Memory Guide at Kingston.com/flashguide.
* Limited warranty based on 5 years or "SSD Life Remaining" which can be found using the Kingston SSD Manager (Kingston.com/SSDManager). A new, unused product will show a wear indicator value of one hundred (100), whereas a product that has reached its endurance limit of program erase cycles will show a wear indicator value of one (1). See Kingston.com/wa for details.
Robust durability
Engineered to withstand tough conditions, this solid state drive has a shock & vibration tolerance that ensures reliability and longevity. With a MTBF of 2,000,000 hours, it's designed for sustained performance and durability, making it suitable for users who demand stability and resilience. -
High-speed performance
Featuring the NVM Express (NVMe) interface coupled with the Phison PS5007-E7 controller, this SSD delivers fast internal data rates of up to 2700 MBps read and 900 MBps write. It's built to enhance your computing experience with quicker boot times, faster application loads, and smooth multitasking. -
Efficient power management
Optimized for efficiency, this SSD features a power consumption profile that minimizes energy use across various modes—idle at 0.11 W, average at 0.99 W, read at 4.95 W, and write at 7.4 W. This not only helps in reducing your carbon footprint but also ensures that your system runs cooler and more efficiently. -
Expansive capacity
With a generous 240 GB capacity, this SSD offers ample space for your operating system, applications, and data. Combined with multi-level cell (MLC) NAND Flash Memory, it provides a perfect blend of performance and storage, making it an excellent upgrade for users looking to improve their system's speed and responsiveness without compromising on storage space.
- Kingston SKC1000 - SSD - 240 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 240 GB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- M.2 2280
- Interface
- NVM Express (NVMe), Phison PS5007-E7 controller
- 22 mm x 80 mm x 3.5 mm
- 10 g
- 5-year warranty
- Capacity
- 240 GB
- Form Factor
- M.2 2280
- Interface
- 22 mm
- 80 mm
- 3.5 mm
- 10 g
Performance
- Drive Writes Per Day (DWPD)
- 0.7
- SSD Endurance
- 300 TB
- Internal Data Rate
- 2700 MBps (read) / 900 MBps (write)
- 4KB Random Read
- 190000 IOPS
- 4KB Random Write
- 160000 IOPS
- Maximum 4KB Random Write
- 190000 IOPS
- Maximum 4KB Random Read
- 225000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 0.11 Watt (idle) , 0.99 Watt (average) , 4.95 Watt (read) , 7.4 Watt (write)
- Software Included
- Coupon code for hard drive cloning software
- OS Required
- Windows 8 / 8.1 / 10
- Included Accessories
- Half-height half-length PCIe x4 adapter
- Limited warranty - 5 years , Technical support
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 20-1000 Hz
