Kingston 2.5 to 3.5in SATA Drive Carrier
Quicklinx: 9BRVWS00 Mfr#: SNA-DC2/35
Kingston 2.5" to 3.5 inch SSD & SATA Hard Drive Converter
Fits most desktop PC cases, including the iMac and Mac Pro Tower Cases.
This handy, high quality drive converter kit allows installation of all 2.5 inch form factor Solid State & Mechanical Hard drives into a standard 3.5 inch drive bay found in most desktop computers.
  • Converts any 2.5" SATA HDD or SSD to a 3.5" SATA hard drive form factor, allowing it be used in 3.5" SATA drive bay
  • Has built-in vents for good air flow and heat dissipation
  • Universal mounting holes for most common PC cases
  • Screw-less design for simple and fast installation
  • Fit's most PC cases, and the Apple iMac and Mac Pro (Requires available 3.5" Internal Bay)
  • Seamless compatibility
    Designed specifically for PC users, this storage bay adapter ensures a smooth integration with your existing system, enhancing its storage capabilities without the hassle of compatibility issues.
  • Effortless installation
    With a mounting kit included, setting up this adapter is straightforward. It supports a transition from 3.5" to 2.5" drives, allowing for an easy upgrade of your system's storage capacity.
  • Versatile storage solution
    Accommodating both 3.5" and 2.5" form factors, this adapter offers flexibility in managing your storage devices. It's an ideal solution for users looking to expand or streamline their storage without compromising on space or performance.
Kingston - storage bay adapter
Storage bay adapter
Supported Form Factor
3.5" to 2.5"
Expansion Bays
1 x internal - 2.5"
Compatible Bay
1 3.5"
113 g
1-year warranty
Storage bay adapter
3.5" to 2.5"
Storage Controller
No CPU
Bays
1 x internal - 2.5"
1 x SATA 1.5Gb/s
Compatible Bay
1 x internal 3.5"
Mounting Kit
Included
Limited warranty - 1 year
113 g
