Kingston 1GB 333Mhz 200Pin SODIMM DDR 333Mhz / PC2700
Quicklinx: 721HWS00 Mfr#: KVR333X64SC25/1G
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR - module - 1 GB - SO-DIMM 200-pin - 333 MHz / PC2700 - unbuffered
Memory module
1 GB
Memory Type
DDR SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
333 MHz (PC2700)
Latency Timings
CL2.5
Unbuffered
Voltage
2.5 V
Lead Plating
Gold
Limited lifetime warranty (Germany, Austria and France - 10 years)
Pars Xcite 8089; Pars Xpression 8050, D480; ASUS A2000, M6000, W1000, Z9100; BenQ Joybook 5000, 6000, 7000; Clevo D800, D870, M375; Compal AT23, CY30, DCY30, FY30; eMachines M6410, M6809, M6810, M6811; FIC GR1, MD02, MD05, MH47; Gigabyte N411, N512; MSI Megabook M510; M620; S250; Twinhead N14, N15
1 GB
Upgrade Type
Generic
DRAM memory module
DDR SDRAM
SO-DIMM 200-pin
Speed
333 MHz (PC2700)
Latency Timings
CL2.5
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
2.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - SO-DIMM 200-pin
Pars Xcite 8089P , Pars Xpression 8050D, 8050I, D480W , ASUS A2000D, M6000N, M6000Ne, M6000R, W1000N, W1000Na, Z9100N , BenQ Joybook 5000G, 6000, 6000N-V03, 7000, 8100 , Clevo D800P, D870P, M375E , Compal AT23, CY30, DCY30, FY30 , ECS G553, G556, G733 , eMachines M2105, M6410, M6809, M6810, M6811 , FIC GR1, MD02, MD05W, MH47 , Gigabyte N411: ZenBook, N512 , MSI Megabook M510A , MSI Megabook M510C , MSI Megabook M620 , MSI Megabook S250 , Twinhead N14PA, N14PB, N15RB
