Kingston 16GB Kit
Kingston 16GB Kit
Quicklinx: 6DGXWS00 Mfr#: KTD-WS667/16G
All KingstonĀ® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - kit - 16 GB: 2 x 8 GB - FB-DIMM 240-pin - 667 MHz / PC2-5300 - Fully Buffered
Memory kit
16 GB: 2 x 8 GB
Memory Type
DDR2 SDRAM - FB-DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
667 MHz (PC2-5300)
Fully Buffered
Limited lifetime warranty (Germany, Austria and France - 10 years)
Dell PowerEdge 1900, 1950, 1950 III, 1955, 2900, 2950, 2950 III, M600, R900; Precision R5400, T5400, T7400
16 GB: 2 x 8 GB
Upgrade Type
System specific
DRAM memory kit
DDR2 SDRAM
FB-DIMM 240-pin
Speed
667 MHz (PC2-5300)
ECC
Fully Buffered
Compatible Slots
2 x memory - FB-DIMM 240-pin
Dell PowerEdge 1900, 1950, 1950 III, 1955, 2900, 2950, 2950 III, M600, R900 , Dell Precision R5400, T5400, T7400
