All KingstonĀ® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
- Kingston - DDR2 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 667 MHz / PC2-5300 - registered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC Chipkill
- Speed
- 667 MHz (PC2-5300)
- Registered
- OEM Manufacturer Equivalent Part Number
- IBM 43V7356, IBM 43V7355 (x2), IBM 40V6128
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- Lenovo System x3850 M2 7141, 7233; x3950 M2 7141, 7233
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- System specific
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC Chipkill
- Registered
- Compatible Slots
- 2 x memory - DIMM 240-pin
- Designed For
- Lenovo System x3850 M2 7141, 7233 , Lenovo System x3950 M2 7141, 7233
