Kingston 16GB DTVP30AV/ 256bit AES Encrypted USB 3.0 + ESET AV
Quicklinx: 9B0TWS00 Mfr#: DTVP30AV/16GB
Kingston's DataTraveler Vault Privacy 3.0 (DTVP 3.0) USB flash drive provides affordable business-grade security with 256-bit AES hardware-based encryption using XTS block cipher mode, which offers stronger protection than CBC and ECB modes. It protects 100 per cent of stored data and enforces complex password protection with minimum characteristics to prevent unauthorized access. For additional peace of mind, the drive locks down and reformats after 10 intrusion attempts. It also features a read-only access mode to avoid potential malware risks.
Companies can add DTVP 3.0 to their standards list with confidence since its industry-leading NAND and controller design allow for NAND to be interchanged without prequalification and certification of security features. Plus, they no longer have to compromise transfer speeds for safety, due to DTVP 3.0's SuperSpeed USB3.0 technology and backwards compatibility with USB 2.0.
  • Enhanced security
    With 256-bit AES hardware encryption, the Kingston DataTraveler Vault Privacy 3.0 Anti-Virus USB flash drive offers a high level of security for your data. This feature ensures that your files are kept safe from unauthorized access, providing peace of mind when storing sensitive information.
  • Durable design
    Designed to withstand the elements, this USB flash drive is waterproof, ensuring your data is protected even in the most challenging environments. Whether you're caught in the rain or accidentally drop it in water, your data remains safe.
  • Temperature resilience
    Capable of operating in a wide range of temperatures, from 0°C to 60°C, the Kingston DataTraveler Vault Privacy 3.0 Anti-Virus is built to perform reliably under various environmental conditions. This resilience makes it an ideal choice for users who need dependable data storage across different climates.
Kingston DataTraveler Vault Privacy 3.0 Anti-Virus - USB flash drive - 16 GB - TAA Compliant
USB flash drive
Interface Type
USB 3.0
Storage Capacity
16 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash
Software Included
ESET NOD32 Antivirus
Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows XP SP3, Apple MacOS X 10.6.x or later, Microsoft Windows 7 SP1, Windows 8
TAA Compliant
5-year warranty
USB flash drive
Storage Capacity
16 GB
Hardware Encryption
256-bit AES
Read Rate
Up to 165 MB/s
Write Rate
Up to 22 MB/s
Interface Type
USB 3.0
NAND Flash
Password protection, waterproof
TAA Compliant
Software Included
Limited warranty - 5 years
77.9 mm
22 mm
12.05 mm
60 °C
