Kingston DDR4 16 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V registered ECC for Cisco UCS C220 M5SX, SmartPlay Select B200 M5
- Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2666 MHz (PC4-21300)
- Latency Timings
- CL19
- Registered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- Cisco UCS-MR-X16G1RS-H
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Cisco UCS B200 M5, B480 M5, C125 M5, C220 M5, C220 M5SN, C240 M5, C240 M5L, C480, C480 M5, S3260, S3260 M5, SmartPlay Select B200 M5, SmartPlay Select C220 M5, SmartPlay Select C220 M5S, SmartPlay Select C220 M5SX, SmartPlay Select C240 M5, SmartPlay Select C240 M5L, SmartPlay Select C240 M5SX
- Capacity
- 16 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL19
- ECC
- Registered
- Module Configuration
- 2048 x 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
- Cisco UCS B480 M5 Blade Server, C125 M5, C220 M5 LFF, C220 M5SN SFF, C240 M5 LFF Rack Server, C240 M5 LFF Rack Server (Tracer), C240 M5 Rack Server for Microsoft Azure Stack, C240 M5 SFF Rack Server, C240 M5L Rack Server for Microsoft Azure Stack, C480 M5 Standard Base Chassis, C480 ML M5, S3260 M5 Server Node with I/O Expander configurable, S3260 Storage Server, SmartPlay Select B200 M5 (Not sold standalone), SmartPlay Select B200 M5 Advanced 3, SmartPlay Select B200 M5 Basic 1, SmartPlay Select B200 M5 Basic 1 (Tracer), SmartPlay Select B200 M5 High Frequency 2, SmartPlay Select B200 M5 High Frequency 3, SmartPlay Select B200 M5 High Frequency 3 (Tracer), SmartPlay Select B200 M5 Standard 1 (Tracer), SmartPlay Select C220 M5 High Core 1, SmartPlay Select C220 M5 Standard 1, SmartPlay Select C220 M5S Basic 1 (Tracer), SmartPlay Select C220 M5SX Advanced 2, SmartPlay Select C220 M5SX Advanced 2 (Tracer), SmartPlay Select C220 M5SX Advanced 3, SmartPlay Select C220 M5SX Advanced 4, SmartPlay Select C220 M5SX Advanced 5, SmartPlay Select C220 M5SX Basic 1, SmartPlay Select C220 M5SX Basic 2, SmartPlay Select C220 M5SX Basic 3, SmartPlay Select C220 M5SX Basic 4, SmartPlay Select C220 M5SX Expansion Pack 2, SmartPlay Select C220 M5SX High Core 2, SmartPlay Select C220 M5SX Standard 2 (Tracer), SmartPlay Select C220 M5SX Standard 3, SmartPlay Select C220 M5SX Standard 4, SmartPlay Select C240 M5 Standard 1, SmartPlay Select C240 M5L High Frequency 1, SmartPlay Select C240 M5L High Frequency 2, SmartPlay Select C240 M5L Standard 1, SmartPlay Select C240 M5L Standard 2, SmartPlay Select C240 M5L Standard 3, SmartPlay Select C240 M5L Standard 4, SmartPlay Select C240 M5SX Advanced 1, SmartPlay Select C240 M5SX High Frequency 2, SmartPlay Select C240 M5SX Standard 2, SmartPlay Select C240 M5SX Standard 3, SmartPlay Select C240 M5SX Standard 4, SmartPlay Select C240 M5SX Standard 5, SmartPlay Select C240 M5SX Standard 6
