Kingston 16GB DDR4 2666MHz ECC Memory
Quicklinx: DQQDWS00 Mfr#: KTL-TS426/16G
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 2666MHz
Data Integrity: ECC
£101.19 ex VAT
£121.42 inc VAT
Kingston DDR4 16 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V registered ECC for Lenovo ThinkSystem SN850; SR550; SR570; SR590; SR630; SR650; SR850; SR860; SR950; ST550
Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19
Registered
Voltage
1.2 V
Lead Plating
Gold
Lenovo 7X77A01302
Limited lifetime warranty (Russia - 10 years)
Lenovo ThinkAgile VX 1U Certified Node; 2U Certified Node; 2U4N Certified Node; ThinkAgile VX Certified Node 7Y94; ThinkAgile VX2320 Appliance; VX3320 Appliance; VX3520-G Appliance; VX3720 Appliance; VX5520 Appliance; VX7520 Appliance; ThinkSystem SR530; SR550; SR570; SR590; SR860; SR950; ST550
16 GB
Upgrade Type
System specific
Lenovo 7X77A01302
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL19
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
Lenovo ThinkAgile VX 1U Certified Node 7Y93 , Lenovo ThinkAgile VX 2U Certified Node 7Y94 , Lenovo ThinkAgile VX 2U4N Certified Node 7Y92 , Lenovo ThinkAgile VX Certified Node 7Y94 , Lenovo ThinkAgile VX2320 Appliance 7Y93 , Lenovo ThinkAgile VX3320 Appliance 7Y93 , Lenovo ThinkAgile VX3520-G Appliance 7Y94 , Lenovo ThinkAgile VX3720 Appliance 7Y92 , Lenovo ThinkAgile VX5520 Appliance 7Y94 , Lenovo ThinkAgile VX7520 Appliance 7Y94 , Lenovo ThinkSystem SD530 7X21 , Lenovo ThinkSystem SN550 7X16 , Lenovo ThinkSystem SN850 7X15 , Lenovo ThinkSystem SR530 7X07, 7X08 , Lenovo ThinkSystem SR550 7X03, 7X04 , Lenovo ThinkSystem SR570 7Y02, 7Y03 , Lenovo ThinkSystem SR590 7X98, 7X99 , Lenovo ThinkSystem SR630 7X01, 7X02 , Lenovo ThinkSystem SR650 7X05, 7X06 , Lenovo ThinkSystem SR850 7X18, 7X19 , Lenovo ThinkSystem SR860 7X69 , Lenovo ThinkSystem SR950 7X11, 7X12, 7X13 , Lenovo ThinkSystem ST550 7X09, 7X10
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2666MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL19
Standard: PC4-21300
Brand: Kingston
