Kingston 16GB DDR4 2666MHz ECC Dual Memory
Quicklinx: DQQ7WS00 Mfr#: KTH-PL426D8/16G
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 2666MHz
Data Integrity: ECC
£186.63 ex VAT
£223.95 inc VAT
Kingston DDR4 16 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V registered ECC
Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19
Dual rank, registered
Voltage
1.2 V
Lead Plating
Gold
HP 835955-B21
Limited lifetime warranty (Russia - 10 years)
HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant DL180 Gen10, DL325 Gen10, DL360 Gen10, DL380 Gen10, DL385 Gen10, DL388 Gen10, DL560 Gen10, DX380 Gen10, ML350 Gen10
16 GB
Upgrade Type
System specific
HP 835955-B21
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL19
ECC
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10 , HPE ProLiant DL180 Gen10, DL180 Gen10 Entry, DL325 Gen10, DL325 Gen10 Entry, DL325 Gen10 Performance, DL325 Gen10 SMB Solution, DL360 Gen10 All Flash Server for Weka, DL360 Gen10 Compute Server for Cohesity DataPlatform, DL360 Gen10 Low, DL360 Gen10 Network Choice, DL360 Gen10 Performance for Cohesity DataPlatform, DL360 Gen10 Remote Office Branch Office Server for Cohesity DataPlatform, DL360 Gen10 SMB, DL360 Gen10 SMB Network Choice, DL360 Gen10 Solution, DL380 Gen10 48TB Server for Cohesity DataPlatform, DL380 Gen10 96TB Server for Cohesity DataPlatform, DL380 Gen10 All Flash Server for Datera, DL380 Gen10 Entry SMB, DL380 Gen10 for Cohesity DataPlatform, DL380 Gen10 for SAP HANA Compute Block, DL380 Gen10 Hybrid Server for Datera, DL380 Gen10 Network Choice, DL380 Gen10 Network Choice for CTERA, DL380 Gen10 Network Choice for SAP HANA Compute Block, DL380 Gen10 NVMe All Flash Server for Datera, DL380 Gen10 Server for CTERA, DL380 Gen10 SMB, DL380 Gen10 SMB Networking Choice, DL380 Gen10 Solution, DL385 Gen10, DL385 Gen10 Base, DL385 Gen10 Entry, DL385 Gen10 High-Performance, DL385 Gen10 Performance, DL385 Gen10 SMB, DL385 Gen10 Solution, DL388 Gen10, DL388 Gen10 Network Choice, DL560 Gen10 for SAP HANA Compute Block, DL580 Gen10, DL580 Gen10 Base, DL580 Gen10 Entry, DL580 Gen10 Performance, DX380 Gen10, ML350 Gen10, ML350 Gen10 Base, ML350 Gen10 Entry, ML350 Gen10 High Performance, ML350 Gen10 Performance, ML350 Gen10 SMB, ML350 Gen10 Solution, ML350 Gen10 Special Server, ML350 Gen10 Sub-Entry , HPE Synergy 480 Gen10 Base Compute Module, 480 Gen10 Compute Module, 480 Gen10 Premium Backplane Compute Module, 480 Gen10 Standard BackPlane Compute Module, 480 Gen10 w/o Drives Compute Module, 660 Gen10 Compute Module, 660 Gen10 Premium Compute Module
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2666MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL19
Standard: PC4-21300
Brand: Kingston
