Kingston 16GB DDR4-2400MHz ECC Module
Quicklinx: CWKTWS00 Mfr#: KTD-PE424E/16G
Kingston 16GB DDR4 KTD-PE424E/16G Dell 2400MHz ECC Unbuffered RAM Memory DIMM.
Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Unbuffered
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
