Kingston 16GB DDR4 2400MHz CL17 DIMM Memory
Quicklinx: CPBGWS00 Mfr#: KCP424ND8/16
Kingston - DDR4 - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - CL17 - 1.2 V - unbuffered - non-ECC
Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 1200 MHz / PC4-19200 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1200 MHz (PC4-19200)
Latency Timings
CL17
Dual rank, unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
Non-ECC
Module Configuration
2048 x 64
Voltage
1.2 V
Lead Plating
Gold
