Kingston 16GB DDR4 2133MHz Module
Quicklinx: BVF1WS00 Mfr#: KCP421ND8/16
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Dual rank, unbuffered
Voltage
1.2 V
Lead Plating
Gold
HP T0E52AA
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
Generic
HP T0E52AA
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
Non-ECC
Module Configuration
2048 x 64
Chips Organization
X8
Voltage
1.2 V
Lead Plating
Gold
