Compact, capless storage in a metal case.
DataTraveler® 50 is a lightweight USB Flash drive available in capacities from 8GB to 128GB. The drive’s compact, capless design features a metal casing that complements any compatible device and colorful accents that range by drive capacity. Fast USB 3.1 Gen 1 (USB 3.0) performance ensures data transfer of music, video and more is quick and easy. Backward compatible with existing USB 2.0 ports for convenience. DT 50 is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
- Compact, lightweight, capless design
- Metal casing with colorful accent by capacity
- Fast USB 3.1 Gen 1 (USB 3.0) performance
- Kingston DataTraveler 50 - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1
- Storage Capacity
- 16 GB
- Enclosure Colour
- Green
- OS Required
- Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Apple MacOS X 10.8 or later, Windows 8.1, Windows 10
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Enclosure Colour
- Green
- Read Rate
- Up to 30 MB/s
- Write Rate
- Up to 5 MB/s
- Interface Type
- USB 3.1
- Metal body
- OS Required
- Limited warranty - 5 years , Technical support
- 44.9 mm
- 20 mm
- 9.2 mm
- 0 °C
- 60 °C
