Kingston 16GB DataTraveler 2000 AES 256-bit Encryption USB 3.1 Drive
Quicklinx: BVQPWS00 Mfr#: DT2000/16GB
DataTraveler 2000 is designed for global security IT professionals, small-to-medium businesses and corporate end users who require electronic data protection. DataTraveler 2000 is easily deployable in a work environment where multiple devices and operating systems are in use as the drive is OS independent and features hardware-based, full disk AES 256-bit data encryption in XTS mode. Encryption is done on the drive and no software or hardware drivers are needed.
DataTraveler 2000's alphanumeric keypad allows users to lock the drive with a word or number combination for easy-to-use PIN protection. For additional security, its auto-lock feature is activated when the drive is removed from the host device and the encryption key and password are deleted after 10 invalid login attempts to thwart brute force intrusions. DataTraveler 2000 is built with durability in mind as an aluminum cover protects the drive from everyday elements such as water and dust.
DataTraveler 2000 is using Datalock technology licensed from ClevX, LLC. The two companies have worked together for many years as ClevX's innovative security and mobility solutions can be found on other Kingston encrypted USB Flash drives.
Kingston DataTraveler 2000 - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 3.1
Storage Capacity
16 GB
Hardware Encryption
Encryption Algorithm
256-bit AES-XTS
Linux 2.6.x or later, Microsoft Windows Vista SP2, Android, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.8.x or later
3-year warranty
USB flash drive
Storage Capacity
16 GB
Hardware Encryption
256-bit AES-XTS
Read Rate
Up to 120 MB/s
Write Rate
Up to 20 MB/s
Interface Type
USB 3.1
Waterproof, dustproof, Onboard Alphanumeric Keypad
Limited warranty - 3 years
80 mm
20 mm
10.5 mm
