Kingston 16GB 3200MHz DDR4 ECC Reg CL22 DIMM 1Rx4
Quicklinx: FG5TWS00 Mfr#: KSM32RS4/16MEI
Kingston Server Premier is designed specifically for mission-critical server systems that require maximum uptime and stability. Server Premier Modules are built using the same components every time and include advanced product change notification (PCN). PCN ensures ample time for qualification and testing at the customer site. With Server Premier, you can expect the same degree of reliability and performance that IT professionals worldwide have come to depend on from Kingston memory.
Kingston Server Premier - DDR4 - module - 16 GB - DIMM 288-pin - 3200 MHz / PC4-25600 - registered with parity
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
3200 MHz (PC4-25600)
Latency Timings
CL22 (22-22-22)
Single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
Generic
133 mm
31.3 mm
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL22 (22-22-22)
ECC
Module Configuration
2048 x 72
Chips Organization
2048 x 4
Voltage
1.2 V
Lead Plating
Gold
RoHS, JEDEC
