ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
- Kingston ValueRAM - DDR4 - module - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - registered with parity
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 2400 MHz (PC4-19200)
- Latency Timings
- CL17 (17-17-17)
- Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 16 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Module Height (inch)
- 1.23
- Speed
- Latency Timings
- CL17 (17-17-17)
- ECC
- Module Configuration
- 2048 x 72
- Chips Organization
- 2048 x 4
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Colour Category
- Green
- RoHS
