All KingstonĀ® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
- Kingston - DDR2 - kit - 16 GB: 2 x 8 GB - FB-DIMM 240-pin - 667 MHz / PC2-5300 - Fully Buffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR2 SDRAM - FB-DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 667 MHz (PC2-5300)
- Fully Buffered
- OEM Manufacturer Equivalent Part Number
- HP 413015-B21, HP 495604-B21 (1/4)
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- HP Workstation xw8600; HPE ProLiant BL460c, BL460c G5, BL480c, BL680c G5, DL140 G3, DL160 G5, DL360 G5, DL380 G5, DL580 G5
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- System specific
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- FB-DIMM 240-pin
- Speed
- ECC
- Fully Buffered
- Designed For
- HP Workstation xw8600 , HPE ProLiant BL460c, BL460c G5, BL480c, BL680c G5, DL140 G3, DL160 G5, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 High Efficiency, DL360 G5 Performance, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Availability Storage Server, DL380 G5 High Efficiency, DL380 G5 High Performance, DL580 G5, DL580 G5 Base, DL580 G5 High Performance
