Unleash the Beast on your system. The vicious HyperX Beast features a dynamic heatspreader to maximize thermal dissipation for increased reliability. Plus it looks really cool and enhances any system. It's Intel XMP ready so higher-performing frequencies, timings and voltages are just a few clicks away. The Beast gets along well with Intel Core processors and the AMD performance and gaming processors. Put the Beast in your corner and crush your opponents - or just conquer your challenging workload.
- HyperX Predator Beast - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL9 (9-9-9)
- Heat sink, dual rank, eight banks, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, unbuffered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Limited lifetime warranty
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.83
- Speed
- Latency Timings
- CL9 (9-9-9)
- Non-ECC
- Module Configuration
- 1024 x 64
- Chips Organization
- 512 x 8
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 2 x memory - DIMM 240-pin
